2000 Dodge Durango engine cutting out at 2500 rpms.
RICHKANDI
Dodge Durango 2000 135000 4.7 engine. We just bought this vehicle about a month ago and the engine light came on and the engine will cut out when you rev it above 2500 rpms. It does fine when you are driving it unless you go above 2500 rpms and then it cuts out, and I also noticed that the rpm hand doesnt seem to work correctly since this started happening.
Oct 3, 2007 at 11:36 PM
BMRFIXIT
  • 19,053 POSTS
[quote:71b9bf539d="richkandi"]Dodge Durango 2000 135000 4.7 engine. We just bought this vehicle about a month ago and the engine light came on and the engine will cut out when you rev it above 2500 rpms. It does fine when you are driving it unless you go above 2500 rpms and then it cuts out, and I also noticed that the rpm hand doesnt seem to work correctly since this started happening.[/quote:71b9bf539d]
codes codes what's the code
check engine -----------------> codes
get the codes
if its cutting in P/N its ok
but in D you have a problem
fuel pressure ------- tune up............sensor s
good luck let us know
Oct 4, 2007 at 12:00 AM
