2000 Dodge Durango Camshaft Sensor
135,000 MILES • V8 • 4WD • AUTOMATIC
MICKEYOBRIEN
I just replaced my cam shaft sensor, car turns over but will not start?
Feb 21, 2010 at 2:49 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 21, 2010 at 8:20 PM
