2000 Dodge Durango After the veh warms up, has trouble shif
2000 DODGE DURANGO
159,600 MILES • V8 • 2WD • AUTOMATIC
SHANANDO1
My vehicle was leaking alot of transmission fluid (because repair shop loosened the bolts on the pan...unknown until recently). Put stop leak in along with more transmission fluid. Took vehicle to another shop was given an outrageous price to repair leak. When that shop put the pan back on fixed the leak problem, but now when the veh has warmed up (about 20 minutes of driving), having trouble shifting into the 3rd....then after about 5 minutes have trouble shifting out of 1st.
Jan 5, 2009 at 8:48 AM
BMRFIXIT
  • 19,053 POSTS
Need to find out if the correct tranny fluid was used
if not have to drain and flush the system then refill
check you tranny dip stick for the correct fluid specification
also you can have it scanned for codes (tranny codes )
good luck
Jan 5, 2009 at 10:27 PM
