2000 Dodge Durango 4 wheel drive wont engage
2000 DODGE DURANGO
104,000 MILES • V8 • 4WD • AUTOMATIC
PEARLGARDEN
I was driving and accidentally hit the 4 wheel drive and it wont go back into 2WD, it just moves freely up and back. The car will not go into reverse, drive, etc. What could be wrong?
Jan 9, 2008 at 8:03 AM
JET DOC
[quote:c5a62903da="pearlgarden"]Transmission problem
2000 Dodge Durango V8 Four Wheel Drive Automatic 104000 miles
I was driving and accidentally hit the 4 wheel drive and it wont go back into 2WD, it just moves freely up and back. The car will not go into reverse, drive, etc. What could be wrong?[/quote:c5a62903da]
Carbon copy truck, miles, problem...
PEARL, did you get this fixed? Does anyone else know what the problem might be. The wife's Durrango started with the symptoms I've read about the tranny speed sensor, in first to second gear the tranny, in 4wd would slip in/out of gear intermittantly. I've blown off replacing the sensor because the 4wd is very rarely used. Yesterday I bumped the 4wd selector out of 2wd and now the vehicle won't go into any gear, and the 4wd selector isn't hitting any shift position. In fact it freely slides forward and aft. I have no idea if these issues are related but would appreciate some HELP!!!
Jul 14, 2008 at 2:34 PM
WLDCWGRL08
[quote:01b6baae8a="pearlgarden"]Transmission problem
I was driving and accidentally hit the 4 wheel drive and it wont go back into 2WD, it just moves freely up and back. The car will not go into reverse, drive, etc. What could be wrong?[/quote:01b6baae8a]its stuck between gears you may need new rubber bearing which only the dealership sell you need to climb underneath and move your clutch are manually mine does it too
Jul 29, 2008 at 9:09 AM
TURKEYDRAPES
I just recently had the exact same problem as everyone, you try to switch to 4HI or 4LOW and all of the sudden your 4X4 shifter feels like it slipped of gear and now has complete play in it (goes back and forth with great ease). I just took it to a mechanic and it was very simple to fix. There is a pin connecting the 4X4 shifter to the transfer case and it came loose and fell off. Its no big deal and very cheap to fix but it is scary as hell when it happens. I hope I'm not alone when I say this. Hope this helps.
Oct 22, 2008 at 9:46 PM
