2000 dodge durango
2000 DODGE DURANGO
D KLOTZ
i have 2000 durango having problem with poor gas mileage an a bad oder. have replaced the o2 sensor already .still a big problem . only getting 9 miles to the gallon.need to know loctoin of my coil / distributor so i can have it tested. it is a 5.9 liter v8.
Nov 29, 2007 at 8:44 AM
BMRFIXIT
  • 19,053 POSTS
[quote:78bc761a50="d klotz"]i have 2000 durango having problem with poor gas mileage an a bad oder. have replaced the o2 sensor already .still a big problem . only getting 9 miles to the gallon.need to know loctoin of my coil / distributor so i can have it tested. it is a 5.9 liter v8.[/quote:78bc761a50]
You’re going at it the wrong way
You should start by scanning the computer if codes present solve that first
If need help with codes or no scanner you access codes by cycling key on off 3 times read code
Pxxx
Good luck
Nov 29, 2007 at 10:53 AM
