2000 Dodge Durango
2000 DODGE DURANGO
210,000 MILES • V8 • 4WD • AUTOMATIC
WISCO BEAR
battery voltage is to low p1682 , one day my car died took the alternator to get tested and battery the alt they said was good the baterry bad, replaced battery good for a couple days voltage still drops and i will turn the car off and it goes back up and i drive for a couple minutes and voltage meter back down i repeat and same thing happens. then replaced belt looked at tensioner it looked good, belt seemed to help at first than it does the same voltage drop and i turn it off and on twice and know i cant get it to drop any ideas would help!! thought about replacing the alt even though it tested good
Mar 21, 2010 at 4:43 PM
  • 110,244 POSTS
Can you tell me if the voltage regulator is on the alt on your vehicle or if it is part of the PCM?
Mar 22, 2010 at 4:18 PM
