2000 Dodge Durango
205,000 MILES • V8 • 4WD • AUTOMATIC
WISCO BEAR
was driving around all day and all of a sudden i had no brakes. the pedal went to the floor and there was nothing. i inspected all of the lines and there was no leakage and fluid in the resivior. any ideas would help thanks
Nov 22, 2009 at 12:37 PM
  • 31,937 POSTS
Hi there,
If you have no external leaks and the fluid ids full, i would be suspecting a failed master cylinder, the main cup seal may have split causing fluid to by-pass causing no pressure, the pedal to drop and this will show no sign of an external leak, check this out first.
Mark (mhpautos)
Nov 22, 2009 at 12:56 PM
