1999 Dodge Durango water pump
154,000 MILES • V8 • 4WD • MANUAL
DARRELLTACKETT123
how do you change the water pump I can't get the clutch fan off please help me im frustraded with it
Dec 14, 2008 at 5:50 PM
BMRFIXIT
  • 19,053 POSTS
WATER PUMP CAUTION:After removing fan clutch assembly, DO NOT store fan clutch with rear of shaft pointing downward. Silicone fluid from fan clutch may drain into fan drive bearing, causing lubricant failure. Removal 1.Disconnect negative battery cable. Drain cooling system. Remove throttle cable at top of fan shroud. Unsnap coolant overflow tank from fan shroud and lay aside. DO NOT disconnect coolant hose. 2.Remove upper radiator hose. Using Fan Wrench (SP346) from Set (2017DSP), remove fan clutch assembly from water pump by turning nut counterclockwise as viewed from front. DO NOT remove fan clutch assembly at this time. 3.Remove fan shroud bolts and clips. Remove fan shroud and fan clutch assembly as a unit. Locate accessory drive belt tensioner, and rotate tensioner clockwise (counterclockwise on heavy-duty cycle engines) to release tension on accessory drive belt. 4.Note drive belt routing for installation reference. Belt must be correctly routed during installation, or engine will overheat due to water pump rotating in wrong direction. 5.Remove bolts and water pump pulley. Disconnect lower radiator hose and heater hoses. Remove coolant return tube from water pump. Remove bolts, water pump and gasket.
https://images.2carpros.com/forum/automotive_pictures/99387_AP7895s_2.gif
Dec 14, 2008 at 10:03 PM
