1999 Dodge Durango Vehilce Jerks
991,648 MILES • V8 • 4WD • AUTOMATIC
KGBUCKS5
My vehile jerks after a complete stop. When I start to accelerate after going past 30mph it jerks and seems to want to shut off but then accelerate on its own for a while. What's the problem and how do I fix this situation
Jun 6, 2010 at 3:56 AM
  • 75,988 POSTS
Do you have a check engine light on and when was the last tune-up?
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 6, 2010 at 12:20 PM
