1999 Dodge Durango Trouble Code P1756
DAIRYMEDIC
Transmission problem
1999 Dodge Durango V8 Four Wheel Drive Automatic
My wife's Durango has the 5.2l V8, 4 speed automatic, which I believe is the 44RE. She started having problems with it not wanting to upshift into 3rd. I would have to redline the engine to get the transmission to upshift into 3rd, then it would almost immediately upshift again into OD. The transmission fluid looked dirty, metallic, so I changed filters and 5 quarts of ATF+4. No change. I plugged in my OBDII scanner on a whim and got trouble code P1756. What is your best guess?
Apr 9, 2009 at 2:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
P1756 Shift Solenoid #2 (SS2)
Suspect faulty solenoid. If the fluid had metal flakes in it then there is a good chance that the tranny has some internal damage done to it.. it will need removed and checked out by a reputable tranny shop would be my suggestion.
Thanks for using 2CarPros.com!
Apr 9, 2009 at 3:56 PM
