1999 Dodge Durango TRANSMITION ACTING
1999 DODGE DURANGO
135,000 MILES • V8 • 4WD • AUTOMATIC
JIFFYBAY
my durango tranny is acting, if you drive for 10-20 minunts is Ok but if you drive for like an hour when you get to an stop and you leave it won't change in to second untill you lower the rpm, it doen't slip , it just doen't want to change in to second gear..any body haave an idea, I ahev read in other websides of probably shift selenoide..
Aug 1, 2009 at 9:19 AM
  • 110,244 POSTS
That is correct. Chances are the shift solenoid is going bad. It's located in the transmission. You need to remove the trans pan to access it.
Aug 21, 2009 at 4:03 PM
JIFFYBAY
Replaced the governator and the prussure sensor and the trasmissin is now working like new...thanks for the help
Aug 22, 2009 at 12:15 PM
  • 110,244 POSTS
That will do it too. Glad you got it fixed. Let us know if you have questions in the future.
Aug 22, 2009 at 1:10 PM
