Ive had this problem for awhile now. I'm thinking its a rocker arm. but it ticks with the rpms and you can really hear it from inside on the driver side. The rattle/tick moves with the rpms. i have a supercharger on top of the motor so itll be a job if i have to replace something like a rocker. any suggestions? also the truck will idle fine then out of no where it will start sucking air and becomes loud. Then if i let it go for to long the truck wants to slowly stall out. after i give it some gas it idles fine. could it be a tps, iac? everything on the truck is aftermarket, well most of it. any suggestions would be nice. But my main concern is the ticking/rattling. Also my heat knob is all the way turn to high heat and its ice cold a/c. What would cause that?
Oct 28, 2010 at 11:23 AM
