1999 Dodge Durango starting
BAMABOY3205
  • 1999 DODGE DURANGO
  • V8
  • 197,000 MILES
My durango is trying to turn over. I can sit there and turn the key over and hold it and it's like it is about to crank but it won't. I cant figure out if it is the fuel pump or what. Thanks
Wednesday, July 15th, 2009 AT 9:43 PM
STEVEW84
  • 673 POSTS
Do you mean it won't crank or it wont start? If it wont crank then you need to check for power going to the starter. If it won't start then you need to find out what you are missing.
Wednesday, July 15th, 2009 AT 9:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to test fuel pump at the rail and also check if the plugs are getting a healthy white / bright blue spark
