Welcome, does it crank any better in neutral? Can you turn the crank by hand? I'd have to make sure the battery has a full charge and the connections are good. If that checks out, I'd check the circuits at the starter relay, voltage for switch side of relay is hot all the time. Voltage for coil side of relay is hot with key in the crank position. If everything checks out, good voltage and ground for the starter and no starter action, I suspect the starter.
SPONSORED LINKS
Thursday, October 1st, 2009 AT 1:34 PM
