1999 Dodge Durango stalls while driving
150,000 MILES • V8 • 4WD • AUTOMATIC
BEARFAQS
I have this 1999 dodge durango that seems to run fine for a while then all of a sudden it will stall out while driving.
once it restarts, could be right away or have to sit for 10 minutes, it may run smooth for day or it start with a rough idle and will stall out agian.
on a second try it may start and run nice and smooth days.
all other general sensors, distributor, injectors, sensors have been check.
check engine light comes on and off at will.
although the ECM has been checked for fault codes it does not show any problems.
could the ECM still be bad and not report an error code?
and or is this a good place to start by replacing the ECM first??
a mechanic shop has worked on it and has had it idling in his shop for up to 6 hours without a problem, next time it will just stall out and not start.
got any idea's??
Sep 25, 2010 at 3:05 AM
  • 110,248 POSTS
Has the fuel pressure been checked? As far as sensors, they could be working one minute and not the next. I would focus on the crank sensor. That is my first guess.
Nov 6, 2010 at 8:28 AM
