1999 Dodge Durango stalling
1999 DODGE DURANGO
196,774 MILES • V8 • 2WD • AUTOMATIC
NICOLEEE
  • 5 POSTS
vehicle turns off , after driving it for anywhere from 12 to 62 miles . it just stalls,it cranks, but no start,there's no pulse to injectors, gas cuts off
Jun 29, 2010 at 11:31 AM
  • 110,211 POSTS
Do you still have spark to the engine? Will it start with starting fluid?
Jun 29, 2010 at 4:30 PM
NICOLEEE
  • 5 POSTS
no, there is no spark at all
Jun 30, 2010 at 6:44 AM
  • 110,211 POSTS
Then everything is shutting down. Check in the power distribution box. You will find an auto shut down relay. Switch it with another relay with the same part number. Let me know what you find.
Jun 30, 2010 at 3:55 PM
NICOLEEE
  • 5 POSTS
i replaced the auto shut down relay and fuel pump relay, i also replaced the electrical section of the ignition switchdo you think it's the control module?
Jul 1, 2010 at 4:08 AM
  • 110,211 POSTS
It could be. It seems that you replaced everything except that. However, remove it and have it checked before getting a new one.
Jul 1, 2010 at 6:22 AM
NICOLEEE
  • 5 POSTS
ok i will do that , thank you !
Jul 1, 2010 at 8:37 AM
  • 110,211 POSTS
Jul 1, 2010 at 1:52 PM
NICOLEEE
  • 5 POSTS
ok, thanks !
Jul 2, 2010 at 3:45 AM
