1999 Dodge Durango Signal lights
135,000 MILES • V8 • 4WD • AUTOMATIC
WEMERLIN
The signal lights on our durango are not working. We have replaced the switch on the column, checked the fuses, bulbs, and flashers. They all check out okay. Any ideas.???
Aug 20, 2009 at 8:35 AM
  • 110,251 POSTS
When you replaced the switch, did you have power to the switch? Are the other lights working?
Aug 21, 2009 at 3:23 PM
WEMERLIN
There is power to the switch and all other lights are working. The signal lights started to fail occasionally, then kept getting worse until they no longer worked at all.
Sep 2, 2009 at 1:03 AM
  • 110,251 POSTS
I hate to say it, but if the fuse is good, you will need to start tracing the power supply back to find a break.
Sep 2, 2009 at 1:16 AM
