1999 Dodge Durango rear brake problem
120,000 MILES • V8 • 4WD • AUTOMATIC
KURT1963
when driving truck and you go to stop and start out the back brakes will not release right away. also with the truck up on jack stands not running and you step on the brakes only the fronts apply is this suppose to happen . i think i meant have a problem with the proportional valve. need help thanks kurt
Mar 23, 2009 at 11:16 AM
  • 110,248 POSTS
Kurt,
If the brakes are sticking, they must be working. Are they properly adjusted? If they are far enough out of adjustment, they won't appear to work properly. When you have the rear up, if you pump the brakes, will the rear work?
It's unusual for the proportioning valve to go bad.
Let me know about the adjustment.
Apr 2, 2009 at 1:46 AM
