1999 Dodge Durango PROBLEM STARTING FIRST TIME
130,000 MILES • V8 • 4WD • AUTOMATIC
WILLIAMSIR
PROBLEM STARTING FIRST TIME OF THE DAY. RUNS FINE ONCE I FINALLY GET IT STARTED. REPLACED FUEL PUMP BECAUSE I WAS TOLD THAT COULD BE THE PROBLEM, IT WASN'T. ENGINE TURNING OVER BUT ACTS LIKE IT IS NOT GETTING GAS. SOMEONE TOLD ME THAT THERE IS A SENSOR ON THE MOTOR THAT REGULATES THE FUEL COMING FROM THE FUEL PUMP TO THE INJECTORS. IS THIS RIGHT? AND WHERE IS IT LOCATED?
May 11, 2010 at 1:38 PM
  • 75,988 POSTS
Check the actual fuel pressure with a gauge if its within specs and also check if the injector/s are pulsing
May 11, 2010 at 9:16 PM
