1999 Dodge Durango Powersteering
114,000 MILES • V8 • 4WD • AUTOMATIC
DENOUTLAWS
My powrsteering seems to be running out pretty fast I fill her up one day and about couple days later it is low agian I think that there could be a leak but could it be something else as well.
Feb 16, 2008 at 7:29 AM
BLACKOP555
  • 10,386 POSTS
The only way it will be escaping is due to a leak, it doesnt disentegrate or burn off. look for wet power steering hoses and around everything else around the pump.
Feb 16, 2008 at 10:29 AM
KD7YNB
  • 18 POSTS
I have a 99 durango. i just replaced the high pressure steering hose. They tend to leak around the metal high pressure clamps. The whole hose needs to be replaced if thats the case. I have done this repair to 3 durango's and its the same thing, so hopefully its that for you. The hose is about $20 and relatively easy to install if you have good experience. Make sure you bleed the system properly. Hope this helps.
Feb 26, 2008 at 12:08 PM
