1999 Dodge Durango plz help
1999 DODGE DURANGO
132,000 MILES • V8 • 4WD • AUTOMATIC
JLK1982
i have a 1999 durango ive done nothing but the drive shaft going too the front drive axil (i can move it side too side and up and down lotta slop)whines.so can i drop it and still drive it?
May 20, 2010 at 3:08 PM
  • 110,240 POSTS
I believe it bolts to the converter and there is a u-joint on the front. However, if there is a problem in the transfer case or the differential, the sound will still be there. Also, please note that we recommend keeping the vehicle the way it was designed. Other problems could occurr.
Are you sure it doesn't just need a u-joint?
Jun 7, 2010 at 6:47 AM
