every time i stop my check gauges light comes on and oil pressure gauge drops to zero as i sit the oil pressure going back up to normal
Mar 5, 2009 at 6:09 AM
✓Experienced Mechanic
Hi:
When the gauge drops, how low does it go? Do you ever hear any knocking or ticking from the engine?
Mar 10, 2009 at 9:44 AM
DSTUBER
MEMBER
I spent about $100 to find out that in my Durango it was caused by an intermittent pressure sensor, not an engine problem.
Mar 26, 2009 at 6:53 AM
Hi:
That is why I wanted to know if you were hearing any knocking or ticking when it dropped. If you didn't, the oil sending unit was the problem. If you did, then I would have looked at the engine.
Regardless, I'm glad it's fixed. Let us know if you have questions in the future.
