1999 Dodge Durango Location of crank shaft sensor
18,500 MILES • V8 • 4WD • AUTOMATIC
KCMILESSR
i am repairing my truck...i replace fuel pump, relay switch, and i am trying to find the location of the crank shaft sensor.
Nov 4, 2008 at 10:44 AM
DOCFIXIT
  • 18,828 POSTS
Top of cylinder block next to right head
Nov 6, 2008 at 4:41 AM
JAMIKAY
On my Dango I had to remove some screw off of the inner wheel guard on front passenger side, then remove air cleaner box in order to be able to reach my crankshaft sensor. It was behind the tire and even in the Chiltons manual it shows it at the top or somewhere easy to get to. Not quite the case. You have to reach pretty far in about elbow deep to access it. The whole process took about 30 minutes for me. Good Luck
Jan 25, 2009 at 6:18 AM
