1999 Dodge Durango engine dies
198,000 MILES • V8 • 4WD • AUTOMATIC
CRITTERZBACK
my 99 5.9 magnum durango will die while driving and sometimes sittin idle. have replaced coil and crankshaft positioning sensor and hasnt fixed the problem. it will restart after stalling. when it does this the fuel pump does not come on and the digital odometer reads no bus i think. but when it will start back up it reads the numbers again
Jul 24, 2010 at 4:12 AM
  • 110,248 POSTS
The no bus means you are losing communication with the computer. Check the wiring harness to the PCM to make sure it is tight and not corroded.
Let me know what you find.
Aug 4, 2010 at 1:23 PM
CRITTERZBACK
[quote:4bb9ee1cf5="Jacobandnickolas"]The no bus means you are losing communication with the computer. Check the wiring harness to the PCM to make sure it is tight and not corroded.
Joe[/quote:4bb9ee1cf5] ended up swapping out the computer and runs like a top now. thank you!
Aug 5, 2010 at 4:52 AM
  • 110,248 POSTS
I'm glad it is fixed. That is why you were getting the no bus. Let us know if you have questions in the future.
Aug 5, 2010 at 5:48 PM
