1999 Dodge Durango engine dies
CRITTERZBACK
  • 1999 DODGE DURANGO
  • V8
  • 4WD
  • 198,000 MILES
My 99 5.9 magnum durango will die while driving and sometimes sittin idle. Have replaced coil and crankshaft positioning sensor and hasnt fixed the problem. It will restart after stalling. When it does this the fuel pump does not come on and the digital odometer reads no bus I think. But when it will start back up it reads the numbers again
Saturday, July 24th, 2010 AT 11:12 AM
  • 109,779 POSTS
The no bus means you are losing communication with the computer. Check the wiring harness to the PCM to make sure it is tight and not corroded.
Let me know what you find.
Wednesday, August 4th, 2010 AT 8:23 PM
CRITTERZBACK
Ended up swapping out the computer and runs like a top now. Thank you!
Thursday, August 5th, 2010 AT 11:52 AM
  • 109,779 POSTS
I'm glad it is fixed. That is why you were getting the no bus. Let us know if you have questions in the future.
Friday, August 6th, 2010 AT 12:48 AM
