1999 Dodge Durango coolant
134,000 MILES • 4 CYL • 4WD • AUTOMATIC
CHERRYBIG
I notice that my coolant fuel is leaking from my carl when I check to see if my radaitor had fuel in it . it was full and didnt need anything the radaitor is not running hot are anything im trying to see if my coolant resvior have a leak in it when i was putting some coolant in it i noitce it was running out. do my radaitor needs replace or something else does
Jan 17, 2008 at 7:00 AM
BLACKOP555
  • 10,386 POSTS
first of all, you will have to look where the coolant is leaking, start the vehicle and look it all over the place for a leak.
Jan 17, 2008 at 11:11 AM
CHERRYBIG
Well it seem like the coolant is leaking from the resvior tank that on the side of the radator because I notice that my coolant tank is empty now. and there radiator is still not running hot and have fuel in it
Jan 21, 2008 at 5:36 AM
BLACKOP555
  • 10,386 POSTS
in that case replace your tank if you see it coming from the resevoir tank.
Jan 21, 2008 at 8:15 AM
