1999 Dodge Durango BRAKES MAKING NOISE
1999 DODGE DURANGO
104,000 MILES • V8 • 4WD • AUTOMATIC
NEK101R
When the brakes were replaced they sounded find after about 3 miles the front passenger side brake started to make a grinding sound but whe the break is applied the noise goes away when you release the brake the noise comes back.
Dec 26, 2007 at 1:07 PM
  • 31,937 POSTS
Hi there,
Remove the pads and inspect for any problem like a stone stuck up behind the backing plate, if nothing is found reassemble taking care to make sure all components are assembled correctly and that all the retaining pins & clips are not touching the rotor, check that the backing plate is not touching the rotor and the wheel bearings are serviceable.
Mark (mhpautos)
Dec 26, 2007 at 1:12 PM
