1999 Dodge Durango 5.2L Oil Pressure
JBTUFTS
I have a 1999 Dodge Durango 5.2L that has 115,000 miles on it. After it's been sitting for a day or so, when I start the engine, the oil pressure guage will stay at zero for about 5 or 6 seconds, then will go up to where it seems to be working. Sometimes it stays at zero long enough for the "check gauges" light to come on for a second or two. When re-starting it after I've been running it. the guage jumps right up without any delays. The engine runs great with no other problems. It's had regular oil and filter changes. Any ideas on what might be causing this?
Thanks!!!
Oct 29, 2007 at 4:15 AM
RICK390
  • 7 POSTS
i believe what you are experencing is an intermittent oil pressure sending unit and they generally dont cost mush more than 100.00
Oct 29, 2007 at 4:53 AM
