1999 Dodge Durango
SUPAFRESH
Engine Mechanical problem
1999 Dodge Durango Automatic 111248 miles
my s.u.v. won't stay turned on. it dies immediately after the initial start. as soon as i turn the key the engine turns on but will die right after. if i press the accellerator immediately after i turn the key, the engine will keep revving but as soon as i depres the accellerator, the engine dies. the radio works fine though so i'm assuming the battery is ok....what could be the problem?
Feb 20, 2008 at 9:54 AM
MASTERTECHTIM
  • 4,750 POSTS
the causes of this are endless but i would first check the idle air control valve. this valve is used to control the idle. if you lightly press the throttle will the truck start and continue to run ok?
Feb 20, 2008 at 10:01 AM
MASTERTECHTIM
  • 4,750 POSTS
this usually means the idle air control valve is not working. try cleaning it and clean the iac
Feb 21, 2008 at 4:26 AM
KD7YNB
  • 18 POSTS
I had this problem with my 99 durango. The PCM was faulty causing a po505 idle air malfunction. Also could lead to intake manifold leak. I would have this checked by a certified technician.
Feb 26, 2008 at 12:05 PM
