1999 Dodge Durango
RYANKDX
Engine Mechanical problem
1999 Dodge Durango V8 Four Wheel Drive Automatic
I have a durango 99 , 360 . it got puuled into water, water in the intake. I changed the oil got all the water out, the motor turns. It has a orange spark from the distributer. my question what be the next step? and is that enough spark to fire the motor?
Jun 17, 2010 at 3:54 AM
  • 110,248 POSTS
If you got all the water out, that is good. I hope you removed the plugs to crank it the first time just in case there was any water in there. If there was, it could have bent a rod.
As far s the spark, you want a blue spark. It may run with what you have, but I can't say how good it will.
Jun 18, 2010 at 8:21 AM
