1999 Dodge Durango
160,000 MILES • V8 • 4WD • AUTOMATIC
ALLOCCA
I tried to start my truck this morning and it will turn over but not catch at all. It has gas and I have no idea what could be wrong. Any help?
May 16, 2010 at 7:48 AM
  • 75,988 POSTS
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 22, 2010 at 4:30 PM
