1999 Dodge Durango
1999 DODGE DURANGO
130,037 MILES • V8 • 4WD • AUTOMATIC
THEBUILDER327
1999 Dodge Durango, the computer will not communicate with any shop scanners, the vehicle failed smog because the tech could not retrieve any of the onboard computer information. The car runs good with no problems at all. We have tried different scanners with different adapters and there just is no response. Checked all fuses and did wigle tests to no avail. Can you help us.???
May 14, 2009 at 6:54 AM
DOCFIXIT
  • 18,828 POSTS
hi
Need to pin test from Data link to PCM. Check continuity with high impedence ohm meter.
Data link PCM
#6 Viloet/white to #29
#7 Pink to #27
#3 Violet/brown to #30
Unplug connector from PCM to check. if open found repair wire if none then PCM Bus maybe faulty.
Let me know
Thanks for donate
May 15, 2009 at 5:53 AM
