1998 Dodge Durango wont change from defrost to vent
ALLENPURCELL
Air Conditioning problem
1998 Dodge Durango V8 Four Wheel Drive Automatic
need to know to get off defrost and to vent it wont switch over and yess blower is working
May 23, 2010 at 1:54 AM
  • 110,244 POSTS
Chances are you are looking for a vacuum leak in this case. Check under the dash and the hood for leaks. The vent doors are actuated by vacuum. If the vacuum pressure is too low, it won't switch.
Let me know what you find.
NOTE: If you are lucky, with the engine running you may hear a hissing from a leak.
Feb 4, 2019 at 10:11 AM
