1998 Dodge Durango window falls
75,000 MILES • V8 • 4WD • AUTOMATIC
PREACHKJV
A1998 DODGE DURANGO SLT,V-8 REAR PASS. WINDOW KEEPS FALLING. THE SWITCH WILL NOT RAISE IT.WHAT TESTS WILL HELP ISOLATE PROBLEM? MOTOR,SWITCH, OR REGULATOR ?
Aug 11, 2009 at 2:42 PM
  • 110,248 POSTS
Remove the door panel. Chances are the motor is loose. Also, you could have a stripped gear.
Aug 21, 2009 at 3:45 PM
