1998 Dodge Durango will not run
197,234 MILES • V8 • 4WD • AUTOMATIC
NETVRDY
driving do the road around 65 mph then it just died will not restart.. its has spark and gas ,,,,,you can hear the fuel system when you turn it on.
Jul 27, 2010 at 2:26 PM
  • 75,988 POSTS
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Jul 27, 2010 at 6:48 PM
