1998 Dodge Durango will not run
NETVRDY
  • 1998 DODGE DURANGO
  • V8
  • 4WD
  • 197,234 MILES
Driving do the road around 65 mph then it just died will not restart. Its has spark and gas, you can hear the fuel system when you turn it on.
Tuesday, July 27th, 2010 AT 9:26 PM
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Wednesday, July 28th, 2010 AT 1:48 AM
