1998 Dodge Durango REAR LIFT GATE
1998 DODGE DURANGO
125,000 MILES • V8 • 4WD • AUTOMATIC
DON NEFF
I THINK LINKAGE HAS CAME OFF LATCH AND OUT SIDE DOOR OPENER.YOU CAN HEAR IT CLICK WHEN YOU USE KEY FOB,AND WHEN USE OF KEY IT DONT WORK EATHER. I CAN NOT GET INSIDE DOOR PANEL OFF BECAUSE CANT GET TO LOWER SCREWS WITH DRIVER. HOW CAN I GET THE DOOR OPEN? SHOULD I DRILL A HOLE WITH AHOLE SAW? DO HAVE ANY IDEALS TO HELP ME OUT? THANKS,NEFTY
Sep 7, 2010 at 12:38 PM
DAVE H
  • 13,384 POSTS
Hello .. Thanks for the donation .. much appreciated
I would remove all the screw's you can from the trim panel and bend it back as far as possible to get to the latch and open the door to locate the problem ! it will be easier to replace the trim panel if it breaks than to fill a whole in the door .. !
Sep 16, 2010 at 7:01 PM
