1998 Dodge Durango Light switch
JACKBIRD13
Electrical problem
1998 Dodge Durango V8 Four Wheel Drive Automatic
first my headlights were not working, changed out the switch, now when I turn on the lights, the parking lights go out.
Dec 2, 2009 at 1:00 PM
JDL
  • 16,098 POSTS
Welcome to the forum, the headlamp switch has two circuits, there is a circuit breaker side of switch only for headlamps. The other circuit is for exterior lites and such. Pink wire with red tracer carries voltage to headlamp switch, hot all the time. Black wire with yellow tracer carries voltage from headlamp switch to external lites, when switch is activated. There may be a multiwire connector under the dash, close to steering column, where you can check those voltage circuits, use a test lite. All repair info says to dis-arm air-bag, where applicable, when working around steering column.
Dec 3, 2009 at 3:31 AM
