1998 Dodge Durango knocking in steering
15,738 MILES • V8 • 4WD • AUTOMATIC
JASON ALICEA
there is a noise in the steering like a knocking sound that occurs driving normal and when you go over a bump or are turning right or left ,slow or fast. why?
Nov 9, 2010 at 12:27 PM
CARADIODOC
  • 34,413 POSTS
Steering shaft. It is a two-piece assembly that slides together in the event of a crash. The fix is to replace it but I heard of one fellow who used brass shim stock to stick between the two parts and it has held up very well.
A new assembly will have play in it when you twist the two halves in opposite directions. That is normal and the play goes away when you extend the shaft to install it. If you find the part number of the shaft you need, I have a half dozen new ones still in the packages. I DO know mine are the wrong part number for a 2000 model.
caradiodoc
Nov 12, 2010 at 7:42 PM
JASON ALICEA
where is the part number located
Nov 14, 2010 at 7:10 AM
