put plugs in 360 engine that was running rough and it ran ok for a few minutes then fouled them and began to run rough again. The pipe from the Cat to the Muffler gets red so i cut off the muffler and it does the same thing. Now it is shooting flames out of the pipe and still running rough. I changed the plugs again and it does the same thing. I am getting a code (not a check engine) of exhaust pipe temp on lower bank1 or something like that. I am thinking it is getting too much fuel not sure how to fix it. all the gauges read normal not overheating and no antifreeze in the oil, i dont thik it is a head gasket. just bought the truck used so i dont know what has been done to it prior.
Aug 27, 2009 at 12:15 PM
