1998 Dodge Durango abs and brake light
120,000 MILES • V8 • 4WD • AUTOMATIC
KSRAIDER
Brake light and ABS light came on and stayed checked front and rear brakes, fluid level, coded with a MAC coder. code was a 72, can you help?
May 27, 2008 at 3:56 AM
SLIPPY311
I replaced the Rear ABS Sensor (located on the differential) and my problem was solved. I also at the same time had an issue with my speedometer not working until I got over 30 MPH and replacing this sensor fixed that issue as well.
May 28, 2008 at 7:45 AM
