1998 Dodge Durango
SHMUNDY
Engine Cooling problem
1998 Dodge Durango V8 Automatic 125000 miles
How do I remove the fan from the water pump?
Oct 4, 2009 at 11:02 AM
MARKIE777US
  • 14 POSTS
ive had to remove mine a couple of times you willl need to get something to hold the waterpump pully from turning, get a 12 inch cresent wrench to fit the nut on back of clutch and a 4 lb hammer, place the wrench onto the nut after locking down the waterpump pully, carefully hit the wrench with the hammer to the left, should break loose within a hit or three, then continue to remove from waterpump, oh you will need to remove the shroud in order to get fan out, the shroud should take 10mm socket
Jan 13, 2010 at 5:04 AM
