Coolant leak
J.S.HARRISON
  • 6 POSTS
Engine Cooling problem
1998 Dodge Durango V8 Automatic
i have a serious water leak to the point where i'll have to put water in my truck every day the leak is coming from rite behind my my fan and its runnig out. I cant seem to see exactly where the leak is comming from to know what its is i need t do to fix it or even if i can fix it. can anybody tell me where that leak mite be comming from
Feb 13, 2009 at 4:10 AM
JDL
  • 16,098 POSTS
Hello, Are you talking about the engine cooling fan? I'm not sure if your talking about the water pump side, or radiator side?
Oct 16, 2020 at 4:49 AM
J.S.HARRISON
  • 6 POSTS
I'm thinking it has to be the water pump side I'm sure its not coming from the radiator. it's like the leak is coming from the space between the engine and the belt rotors
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_durango_1.jpg
Can you tell if it might be a hose or the water pump itself?
J.S.HARRISON
  • 6 POSTS
from looking at the diagram i think it has to be coming from the D section either that water pump or the pulley i don't think its the bypass hose the water seems to be leaking from a lower part of tat area. Is that something i would have to take to a mechanic or the dealer or is something simple i can change in my driveway.
JDL
  • 16,098 POSTS
Hello, sorry I didn't post back sooner. If you think it is the water pump itself, you should be able to do that.
J.S.HARRISON
  • 6 POSTS
Thank you so much for the information for my truck
