2004 Dodge Durango Tapping Noise
JOESMAMA4
I have a 2004 Durango ST, approx. 50K miles on it, w/ 4.7 L engine (no hemi). There's been a tapping noise (sounds like rocks being thrown at the floor board) that you can also feel underneath drivers side floor boards. Brought it to dealership, they replaced a bad tie rod and fixed a loose piece of the body & we purchased new tires.
After we brought it home, the noise continued and got worse. Took it back to the dealership, they proceeded to tell me that the whole front end looked fine. Well, I don't know much about cars, but I know that sound isn't normal. Also, on the way to the dealership, the ABS light came one. It's being replaced and the tech told us that the ABS is what was causing the tapping. Also that the ABS will tap and the brake pedal will pump when engaged. Well, I know this, we lived in Alaska for 5 years and had many occasion for it to engage. It's not the same noise or feeling!
Other details..... It only occurs at lower speeds (either that or the engine noise covers the sound at higher speeds.) , it happens after driving for awhile or if it's hot out, it happens no matter whether you're braking, coasting or accelerating.
I need to know what else it could be, or if the ABS could really have been causing it all this time. (been happening for about 6 months). I don't want my car to leave the dealership without this being fixed!!
Aug 26, 2007 at 3:36 AM
MERLIN2021
  • 17,250 POSTS
The only thing I found on your truck that might be your problem is the Exhaust has a TSB for the muffler and tailpipe hangers...seems the bolted the system to the frame! The TSB has 2 part #'s to fix it.
05161304AA...Tailpipe hangar
05161308AA...Muffler Hangar
You might want to see if this has been done.
Aug 26, 2007 at 4:28 AM
JOESMAMA4
I forgot to mention that this problem usually occurs after i've been driving for awhile and/or when it's hot outside (I currently reside in Georgia.). This problem is driving me so crazy, I browsed other forums (there are A LOT of other people with this issue) and they've suggested that it is a worn body mount, that the ball joints and end links need replaced, etc... But nothing seems to fix it. Any other input or suggestions??
Aug 26, 2007 at 6:00 AM
Suggested Repair
Check whether the exhaust TSB for muffler and tailpipe hangers has been done. If the exhaust is bolted to the frame, install tailpipe hanger 05161304AA and muffler hanger 05161308AA.
Conversation Summary
A 2004 Dodge Durango with a 4.7L engine has a tapping noise felt under the driver's floor at lower speeds, worse after driving or in hot weather. The dealer replaced a tie rod, tightened a loose body piece, and later blamed the ABS, which the owner says does not match the noise. An expert points to an exhaust TSB for muffler and tailpipe hangers bolted to the frame and gives the replacement part numbers.
