1989 Dodge Diplomat fuel pump
1989 DODGE DIPLOMAT
128,000 MILES • V8 • 2WD • AUTOMATIC
MICHAEL FECHTEL
how to change fuel pump on the dodge
Dec 27, 2009 at 2:18 PM
CH112063
  • CAR REPAIR CONTRIBUTOR
  • 1,320 POSTS
to replace a fuel pump on a 318 you'll need to also get a new filter, and change the rubber hoses also, there is no taking anything off, just dis-connect the hoses at the filter or just use a wire cutter to cut them, and then take the two bolts out using a ratchet and extension its a tight fit but there is a new gasket if you get a new one fron mopar and just use a scraper, clean the surfaces good and install the new one.
dis-connect the negative battery cable so you don't have any problems and try not to get any fuel on your skin or in your eyes. if ya run into trouble let me know, instructions come in the new pump.
Jan 12, 2010 at 8:45 PM
