2000 Dodge Daytona air not cool
140,000 MILES • 6 CYL • 2WD • MANUAL
KASINOKAT
My air is starting to blow warmer air out. If I turn the fan motor to lowest setting the air is cool, if fan is on highest setting the air starts getting warmer. I can hear the compressor clicking on and off like normal. Do I just need freon?
Jul 19, 2010 at 12:07 PM
  • 31,937 POSTS
Hi there,
You well may be low on refrigerant, but just adding more will not fix the [problem, if it is low there is a leak in the system that will have to be taken care of first, a leak detector dye added to the system will help locate any leak, start here.
mark (mhpautos)
Jul 19, 2010 at 12:33 PM
KASINOKAT
Thank you so much for responding to my question regarding my a/c. Can you tell me about how much it will cost to do the dye test and add coolant? Thank you so much.
Jul 19, 2010 at 1:05 PM
  • 31,937 POSTS
Hi there,
As i am in Australia, my pricing on service work may not be what you will be paying, but i would not expect more than 30Min labour & about $25 for the leak detector, as it is just added to the low pressure side with a small top up charge of refrigerant, then you will have to re visit the work shop after a few days or using the air , to see if the leak dye has worked, but i would ring a few of your local work shops and get a closer price range.
mark (mhpautos)
Jul 19, 2010 at 1:16 PM
KASINOKAT
Thanks again
Jul 19, 2010 at 1:22 PM
