turns over fine , not getting any fire, plugs are fine, replaced coil, fuel pump is ok, fuses are ok, what could it be?
Jul 25, 2010 at 1:42 AM
✓Experienced Mechanic
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
