1992 Dodge Daytona 2.5L
1992 DODGE DAYTONA
JOE NAFFAH
NO heat coming out of the heat vents, just cold air. We've replaced the thermostat, water pump and coolant. We've run water through the heater core and all the lines and water runs through it. How do I know if this car has a "heater control valve" as am unable to find a tech manual on this car. If it does, where is the heater control valve??? Thanks, Joe
Feb 12, 2006 at 4:01 AM
PEPPERMRJ
  • 1,158 POSTS
One of three things come to mind.
1 The temperature door cable is broke, binding, or disconnected.
2 The heater core is clogged. Ever use any type of radiator stop leak products.
3 It does have a heater control valve, it is malfunctioning or not hooked up properly. In the old days they were in the heater hose. Now I do believe they are part of the heater/AC assembly unit.
The link in blue at the left of this page "Repair manuals" should be able to provide you with a hard copy tech manual.
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Here is a link to a generic repair manual for front wheel drive Dodges.
http://www1.autozone.com/servlet/UiBroker?UseCase=RG001&UserAction=processEngine&Parameters=004
Feb 12, 2006 at 4:31 AM
