1991 Dodge Daytona shifting 1-2, & 2-3 requires high rp
DOXCHELSE
  • 1991 DODGE DAYTONA
  • 6 CYL
  • 80,000 MILES
Replaced tps, and now it drives erratically. Hard downshift from 2-1, shifting from 1-2 occurs @ 21 mph, and 2-3 @ 36mph. Will not shift into od. BUT, on occasion, it drives fine. I have gotten trouble codes, 24, 15, 42, & 35
Thursday, August 5th, 2010 AT 3:25 AM
KHLOW2008
  • 41,814 POSTS
Hi doxchelse,
Thank you for the donation.
Here are description of the trouble codes.
Code 15 = Vehicle Speed signal. No distance sensor signal detected with road load conditions.
Code 24 = TPS voltage low or High. TPS sensor output less than minimum or more than maximum output. The TPS could have be installed wrongly or adjusted out of range.
Code 35 = Radiator Fan relay. Open or shorted condition detected in radiator fan circuit.
Code 42 = ASD relay circuit. Open or shorted condition detected in ASD relay circuit.
Code 42 = No ASD relay voltage sensed at SBEC. No ASD relay voltage sensed when ASD relay is energized.
Code 42 = Z1 voltage sense. No battery voltage sensed when ASD relay is energized.
Erase all codes and drive around till condition appears. Recheck trouble codes to see if all of them appears.
Friday, August 6th, 2010 AT 10:14 AM
