1990 Dodge Daytona wont turn over and battery is good and s
80,000 MILES • 6 CYL • FWD • AUTOMATIC
GAYLEN950
I have a dodge daytona and i cant get it to turn over. the battery is good, the starter checked out all right. I checked the fuse box and all is good. Is there any starter relays that could go bad.
Mar 28, 2010 at 1:05 PM
  • 75,988 POSTS
No crank at all/nothing/nada: Could be the starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
https://images.2carpros.com/forum/automotive_pictures/12900_sr_3.gif
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Mar 29, 2010 at 6:48 PM
GAYLEN950
i checked them all with an Ohm meter this morning and the neutral safety switch had no reading. I ran to autozone picked one up for $12.00 put it in and it fired first try. thanks alot. you are awesome.
Mar 30, 2010 at 1:26 AM
